Did a quick search and couldn't find anything even kind of similar to the issue I'm having.
I got everything put on the driver side and the castle nut just kept going and going like the damn energizer bunny. The instructions say to add a washer if the cotter pin hole is too high and after just finger tightening it, I added two washers. Then it didn't even snug up until it got to where the picture shows. It seemed like ALL of the threads had made it through the spindle so I checked the other ball joint in the kit vs the factory one and the taper is definitely thinner than the factory ball joint. The instructions for the Fox coilovers have a note that say they "MUST be used with aftermarket upper control arms" so I would really prefer to figure this out than have to put everything back to stock right now.
Has anyone else run into this issue? Did I get the wrong size ball joints/do they even have different size ball joints for us? Or do I just need to do the uncomfortable thing and stack a ton of washers up under the castle nut?
I messaged them asking about it, but it's Sunday so I'll have to wait for their response.
Did you match the aftermarket ball joint shaft spec to the spec of your OEM knuckles facilitating stamped/aluminum arms or cast arms? The knuckle is different for the two specs. If your truck came with cast arms from factory you need cast spec UCA, if they came with aluminum or stamped from factory you need aluminum or stamped spec UCA- both for reasons of the ball joint shaft hole at the knuckle.
I know in the case of the Cognito UCA I have on order I got the alum/stamped spec, BUT I'm also swapping my OEM knuckles and LCA to aluminum/stamped spec- and I anticipate I might have to swap other relative components once I get that far but I'm not sure at present. I'm not even sure I need to swap the LCA, but I am anyways. I know Cognito makes UCA for OEM cast arm replacement or alum/stamped, and it only matters at the knuckle in the case of that specific component. Perhaps you could even just swap ball joints if needed, but I'm speculating in regard to the parts you have there.
If you originally had aluminum arms could you tell me if your truck came with the X31 off road package? I think that was the determining factor that granted aluminum arms and resultantly spec'd knuckles, but I don't know.
Edited by Truckboattruck
So I did confirm (prior to ordering) that I originally had the stamped steel UCAs. No fault of Kryptonite since I didn't order directly from them, I was sent cast UCA joints. I just ordered the proper ball joints directly from them this morning but it'll be 2-3 weeks before they arrive and since I don't feel like undoing the work, the truck will just stay on jacks in the garage until the correct joints come in. Maybe I'll take the time to make sure my wheels/tires will fit.
I don't believe you need to do the lowers at all. But I'm a fan of going the extra mile, so I'll like to see how it turns out.
Also, I don't have the X31 package. So you may very well be right about that 🤔
Edited by not_a_denali
Glad you got it figured out, and thanks for the X31 info as well. I think there is some confusion going around that the aluminum arms were part of the Z71 package- which my '14 has, but also has cast arms.
I have everything I should need for the knuckle swap except the UCAs, I don't think the aluminum LCA are made anymore however so I went with aluminum Mevotech premium TTX LCA. It should just be the UCA ball joint shaft spec that is different, but I won't be able to tell until I pull the knuckles off and compare in 6-8 weeks.
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
