hi guys, I have a 2014 AT 5.3L with 109K miles.  last week I started hearing a strange knocking noise coming from underneath the truck.  it was during a cold start on a really cold morning.  I could hear it also from the topside.  it sounds like horse steps or empty coconut halves bring hit together, if that makes sense.  its not fast, its actually kinda slow, it goes up a little bit with the rpms.  funny thing is, when it happened I stated googling things and found the vacuum pump TSB/recall so I called GMC.  they ended up replacing it for free and wouldn't you know it the noise stopped. well a week later and its back.  its not all the time.  I got underneath it while it was running but can't really pinpoint it.   it kinda sounds like its from the oil pan.  its time to change the oil so ill start there.  maybe its really low, but I haven't gotten a low oil pressure light lately.
I'm no mechanic but it sounds like you could be describing rod knock.
It sounds like you rely on a low oil pressure light for maintenance purposes? That's not what the warning light is for; it's there to prevent catastrophic engine damage.
A rod knock would be very loud and by now the engine would have grenaded from it. Plus the oil would be full of metal if that let go.
I'd have to hear the noise to try and figure it out better. Just seems odd that the new vacuum pump made it stop but then it came back a little while later.
  • Thanks 1
Horse steps, coconuts halves being hit together? imo that sounds loud, but your the mechanic 😉
no I don't rely on my light for maintenance.  this engine is notorious for being low on oil one day and full the next. I couldn't tell you how many times I've checked the stick to see it bone dry, add a qt, and drain 8 qtz when I change it a week later. I even posted about it a long time ago.
this isn't very loud,  just barely audible over idle.
maybe you should let it rest longer when you check the oil. its possible the oil drain passages are stopped up somewhere in the engine. I would take it back to the dealer and have them check the vacuum pump
oil pressure is perfect, dead center.
changed the oil today, drained 6 qtz,  still doing it but doesn't appear to be as loud.  its not continuous.  it does it a few times then stops, then does it again a few times then stops.  I don't get it.  guess ill take it to the dealership and let them see if they can figure it out.
If your headed to the dealership then it will be extremely expensive and may not even fix the problem.
Before you do that, try "Motor Medic". It takes 5 minutes and might solve the problem.
I solved a LOUD lifter tick and a low oil pressure issue with this stuff that costs...... $5.
I would flush the motor, and change the oil filter brand, and oil weight to something a little heavier. (check manual for options)
I recommend not flushing the motor unless there is a need, and I recommend not changing the oil weight, unless there is a need.
66e902c3-d4ac-4dec-b17b-91e3ac572b5f.4fe
it would help if you could get a better location of the noise. take a long screwdriver and use it as a stethescope by putting the handle against your ear and probing with the blade different spots on the engine. check all the belt driven stuff as well as the engine but watch out for the fan blade
FH07OCT_DIASTE_01-2.jpg?resize=350,350
7 hours ago, richard wysong said:
you know thats what the dealers going to do at $150+ per hour. they aren't magicians
They won't even do that. If there's no codes, there's no problem..
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 654 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
