Hi all, I have a 21 AT4 with the Bose sound package. Sound system was always favoring the front so I adjusted the fader. Come to find out that if I set the fader all the way to the rear the sound is extremely low. Any ideas?
9 hours ago, Transient said:
12 month/12,000 mile bumper-to-bumper warranty?
As with anything else, GM and dealership will say "it's normal".
Sounds like you need a better dealer/service department
Not my service dept. I read thousands of posts here and every time someone has a problem with whatever, the dealer is quick to say "that's normal". Apparently you misread me. Again, if someone brings a truck in for anything that shouldn't be, they'll say it's normal.  Just like the shaking Silverado's. Normal??? Yea right.  When they say something is normal, just tell them, ok if it's normal, lets go try 10 trucks on the lot and if all 10 do it then it's normal.  As for this issue, every '19 up Bose that I've been in has low rear audio. There's nothing any service dept. can do to fix it. It's in the design. Read the many posts and topics on this issue. It is what it is.
1) I didn't "misread" you, and my statement is very applicable to everybody who has issues with their dealer.
2) I have a 2020 with the Bose system.  I haven't recognized this problem.  When I crank the volume up, it's loud.  When I turn the volume is quiet.  It does what I want.  Notice I didn't comment on the specific problem.  I'm not experiencing it.  Just recommended a possible solution that you chose to take exception to.
Then why do I need to find a new dealer? I never brought it in. I have a Bose and it's loud and sounds good but, the rear audio is low. It's the same with all Bose 2019 up Silverado/Sierra. Sure, sitting in tbe front seat it's loud but turn it up loud and go listen to the rear door speakers. In fact, turn up the volume, then turn your fader to rear only.  You'll see what we're talking about. Don't assume rear audio is not low just because "it's loud" with you sitting in the front seat.
Thank you for starting off your last post by doing exactly what I pointed out at the end of my last post.  You took exception about it.  This may be news to you, and maybe this is the first time you've heard it, but not everything is about you.  Now, here's the real question to all this:  Why is somebody so concerned about the rear speakers when the system as a whole works as designed?  Are they occupying the backseat by placing their head between their knees and their butt in the air so their ear is as close to the rear door speaker as possible?  That would be a very uncomfortable ride, especially with the shoulder strap of the seatbelt cutting off blood flow to the brain.
Btw, my truck is also my family hauler.  I have kids in the backseat almost every time I drive.  None of them are complaining about lack of music back there.
And thank you for reiterating my point. The system is designed this way but it doesn't mean the rear audio isn't much lower than the front. OP question. Sure, passengers can hear it just fine but there's enough speakers in the cab that it can be heard. The OP asked about the "rear audio" being low. I said all Bose rear audio speakers are low in the T1. Then you say I need a new dealer? Because my designed rears are low? Really?  No one had ever complained in the rear seats of mine either but the rear speakers are substantially lower than the fronts. Why? I'm not sure and I surmise it's designed this way as I stated for acoustics IDK. Bad design? IDK but it Doesn't mean we need new dealers because it's designed this way. This question was raised when the T1 was introduced. Congrats for having the "only" Silverado in the country with loud rear Bose speakers 👍
What I mean about not loud is that it's grossly low volume.
Fade all the way to the front speakers and turn the volume to 2. That is the loudest the backs get with the volume cranked and fully faded to the back speakers.
That's what I told him to do. Fade from front to rear with volume up and see the difference regardless if back passengers can hear the total sound system. My rear is much lower and no dealer can remedy that. It's the nature of the beast on the T1 Bose.
What bothers me is I can't get any spatial surround sound. It just feels like only the front speakers are playing which is ridiculous.
I see you like to run circles like a dog tethered on a leash outside.  I'm not one of them, so feel free to run as many circles as you like.  Just realize being dizzy is why you can't keep things in context.  Compare what I wrote to what you wrote and you'll see your contradictions.  Keep running circles.  I won't be.
Running circles lol? You're doing a good job yourself. And dude, it's not about running circles it's about you not knowing what you're talking about. Period. If you start something and can't take the heat get out of the kitchen. Furthermore,  do your research before you tell someone to get another dealer especially when you have no idea what you're talking about.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
