On 12/30/2021 at 5:26 AM, Nathan Wellman said:
could someone post a video showing the location of the Canyon's ac drain?
This is not exactly what you were asking for, but it might help.
Part #25.
1591249628897-png.391880
6 hours ago, Nathan Wellman said:
Thanks! Still can’t find the damn thing. Probably best thing is go to the dealer and ask. Then I will post the video.
I assume that its plugged. Otherwise, you could just run the A/C and follow the drips.
On the drivers side in the interior if you lean down under the steering wheel back behind the console you will see a hose about 1/2" diameter exiting through the floor. Down under the truck right above the front drive shaft is where the water exits. There is a silver heat shield or sound material with a hole where the water drips through.
    jgaudet99
    jgaudet99
  • Who's Online   3 Members, 1 Anonymous, 479 Guests (See full list)
