So I went to look at some wheels for my '22 2500 while I wait for it to arrive, figure if I can't have the truck yet, might as well buy the accessories while I wait lol.  The local place told me to not order anything under a +25 offset, as the stock wheels are roughly +40ish offset and anything less than that will rub without a level or lift?  I don't have a lift, and no plan for a lift or level....but they don't make too many wheels in +40 offset, so what is the answer here?  Again, I see tons of pics with lifts and levels, and obviously understand that changes everything, but does anyone know what offsets work WITHOUT a level or lift?
Stock tires on +18 will fit no problem.  I have +10 with 295/65/20 tires and just needed to tie back the fender liner a bit, everything else is stock.
 Thank you!  Thats what I was hoping to hear....I knew the closer I got to 0 or into the negative offsets I'd have an issue, but was hoping +18-20 offset would work!  Thanks again!
Yeah your tire place is wrong. I had +12 wheels with 295/60/20 tires and it was not close to rubbing. You can run 35” tires on +18 wheels and not rub.
