Please help I recently purchased this truck after my last was totaled it ran perfect for two weeks an then randomly started idling really rough wanting to die out. I’ve replaced the fuel pump, spark plugs, starter, positive and negative wires from battery, new MAP sensor an the oil pressure sensor. It’s throwing po106 po507 po573 po2119 codes and when I clear them the truck won’t start. But it will crank up with starting fluid I checked fuel pressure an it’s at 65-70psi on startup please help
Edited by Ashtonross
I would say that there is some sort of problem with your vehicle.
Replacing random parts will only make the problem worse, not better.
Every part that you replace might cause more problems. For instance, if your old fuel pump was working fine, and you replace it with a brand new (but defective) fuel pump - then you have added more problems to the situation, yet you completely discount the fuel pump as an issue, because its brand new. Now you have 2 major problems, and have spend time and money - which only results in a much more difficult diagnosis.
If you want to replace the fuel pump, make sure its actually bad first.
Also, you can spend $1,000 and countless hours replacing random parts, when a diagnostic only costs $100 and takes an hour.
Its all all about the basics:
Fuel
Air
Timing
Spark
Compression
Fuel/air ratio
Which one is not working properly?
I did run a fuel pressure test and it was below 40psi so I replaced the pump now it reads 60 but I still have the same issue. It runs just fine on the road but when coasting or idle it wants to die. I replaced all spark plugs today I haven’t checked all coil packs yet though. The sensors I replaced were all throwing codes to be replaced but replacing them didn’t take the codes away
I bought it off a guy who said he was the only owner it has 96k miles and has been airbagged some of the wiring under the steering column has been messed with but I don’t think any of it is damaged it also is missing the parking brake for some reason
Fuel
Air
Timing
Spark
Compression
Fuel/air ratio
If I was having some sort of spark issue I would think it would give a misfire code an I haven’t got one. After I check for a vacuum leak tomorrow I’m not sure what else it could be thanks for your time
1 minute ago, Supreme Pizza said:
Ya, checking for a vacuum leak couldn't hurt. I used starting fluid for the test, but that's just me.
Could be water in the fuel?
Clogged air filter?
Clogged air filter?
When I changed the tank I drained all the fuel out an put new back in an checked the tank to make sure it was clean. My air filter has been cleaned but it does have a small burn with a pen hole in it from hiting my header. I checked for a vaccum leak with starting fluid today but got nothing so I’m trying with a smoke tester tomorrow
17 minutes ago, Supreme Pizza said:
Might try disconnecting the Mass Airflow Sensor, to see if that helps.
Alright I’ll give that a try thanks
That won't help any. The codes don't point towards the MAF sensor at all.
The codes are MAP and throttle related. Check the harness for damage. Ideally a scan tool would be used to watch the parameters to see what is going on.
I responded to you in the Silverado/Sierra forum.  All those codes seem point to an improperly functioning throttle plate or a bad ECM.  Whether the throttle plate is dirty, bound up, or jammed by debris, you'll have to check out.
If you plan to keep this, get a Tech-2 and a subscription to the shop manual and trouble shooting guide at AllDataDIY or buy a pdf copy off Ebay from SeriousCTBuyer.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 840 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
