Hello all,
My son has a 2008 Silverado 1500 LT, he recently installed an amp & sub box.
The keyless entry quit working so we found that the remote transmitter module was bad so I took it to the dealership to have it programmed the service tech told me he needed the factory radio to program it. So I took the radio to them they had the truck for a week checked all modules & even replaced the new transmitter module, they are saying that it’s losing signal & can’t figure out why. They washed there hands of the truck & charged me $345.00
Any help would be greatly appreciated.
Did the dealership remove the amp and new radio your son put in and then try to reprogram the fob?  How proficient at wiring in all of those things is your son?   I don't think you will get much help here with the issue you are describing sorry to say.. If  a certified GM dealerships service department turned your truck away, something has to be terribly wrong or not obvious.   I am surprised they didnt recommend changing the BCM.  I have seen people do damage (mostly on older cars) by wrongfully hooking aftermarket radios up.  Dead shorts, parasitic draws,  fried wires etc.  The problem with trying to trouble shoot what someone else has done is not knowing where to start..  Most people will try to throw the most obvious things at the problem, but when that doesnt work, its onto the next item.  Your problem could be nothing more then a frayed wire that is losing contact, but its extremely difficult to trace down.
Edited by Sharpz
They did put the factory radio back but I’m not sure if they disconnected the amp, the radio and amp were plug and play except for the power and ground, which I took to the battery and frame.
Thanks Rick I’ll try that.
looking to replace my aging 98 silverado Im always disappointed when I look at a truck thats had the factory system removed. another reason to leave it alone!
Richard, you are so right! The original manufacturers screwed us all with their integration of all systems through the radio. My recommendation is to return the truck to as built configuration and take it to a pro shop. buy the mods from them, pay them to install it all and then if it don't work they can fix it.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 446 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
