My 2000 Gmc sierra 1500 that had a complete frame up rebuild using a 2005 complete rolling chassis as well a low mileage 05 5.3 vortec and the 2005 main wiring harness front to back .problem is the push button 4x4 doesn’t light up but if i pull the 4x4 fuse in the cab and i just barely put the fuse back and wiggle it up and down i get some clicking noise and for a second the push button flickers . is this a bad ground or punched wire causing my problem before i ripped the truck apart because of a rotted frame for the rebuild the 4x4 worked but the 2000 wiring harness was completely full of water and had to be changed . By the way the front drive shaft is removed as well as encoder motor because it was stuck in 4x4
Edited by classicxl
it sounds like you have many issues ongoing.  Making sure all of your grounds are hooked, is the first thing.  I am not sure of the compatibility of your bcm and ecm with a 2000, vs 2005.  It may be a matter of just taking it to your local gm dealership and getting things reprogrammed.  I am not sure what frame up means, but if that means you got a frame, and a cab........... from a 2005, then what exactly did you take from the 2000?
Frame up means everything on the frame was restored to like new condition . story is i bought a 2000 gmc looked mint then discovered the frame was bad behind fuel tank.
My friend who sells gm trucks found a very low mileage 2005 truck that it’s older owner had rolled his tuck into a ditch but everything else was in like new condition. We took my 2000 cab and box and put it on the 2005 frame . used the 2005 wiring harness because mine was full of water and put in a good used computer and it was reflashed
push button switch when i first bought  the truck from the dealer ,  each 4x4 selection button did  light up and worked  now nothing unless i wiggle the fuse it flickers for a second
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
