I might catch some flack for this but I'd like to disable the Daytime running lights on my 22' Custom with crappy Halogens.  I'm ordering led bulbs soon, but want to ditch the DRL's to cut down on the led's kicking on and off.  I checked the fuse boxes (all 3) and I don't see any fuses or relays for DRL.  Have they now made it so that we're unable to do this?
Turn the headlight switch to the left upon start up.  The dash will display "automatic lamps off" or something like that.  That will disable the DRLs when the truck is on, you will have to do it each time you start the truck.  This way has been a thing since at least 2004 on the pickups and still is.
No fuses, its all BCM controlled.
The only other option is custom BCM programming from WAMS, but its $300 where turning the switch to the left is free from GM - 2019-2022 T1 Pickup Custom BCM Programming - White Automotive & Media Services (whiteautoandmedia.com)
Edited by newdude
right, I know about flipping the headlight switch, was hoping for a permanent solution.  When my wife drives the truck she never remembers to flip the switch.  I saw Gen 5 DIY has a harness that converts the dRL's to the marker lights.  That seems like about the best alternative besides what you mentioned newdude.
Are the headlights setup with wires going into them that are controlled for the parking lights along with the low/high beam light wire? If so I can share my experience with changing this in my 2014 headlights that had the crap halogen lights.
My goal was to not have DRL's but retain automatic headlights/parking lights when it gets dark out or when the wipers are on.
What I did was probe the wires going into the headlight harness to find which one is the parking light wire (it will only have +12v constant when the parking lights are on, 0v when the parking lights are off and 0v so long as the turn signals are not on and the high beam wire is not on. Also, the parking light wire will also not have a PWM signal when your daylight sensor bulb in the dash is detecting sunlight.
Once you find that wire you can either take the current low beam + wire and cut it and splice it into the parking light wire or you can use the parking light wire as a trigger to an external relay as I did for my HID's. You don't want to connect the relay directly to the low beam or DRL circuit since they will have a pulse width modulation signal and it will fry your aftermarket lights.
That’s some great info, will have to look into that.  Thanks kickass.
  • 4 years later...
I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
I had a Gen5DIY DRL relocate harness from a 2022 1500 that I saved. I had Gen5DIY modify the harness for my 2024 Silverado 2500. Plug n Play, worked perfectly.
Here's a video I made for the 2022 1500 truck. The install is more or less the same on a 2500.
The harness relocates the DRL tot he top amber turn signal on my 2500.
good to know Dave and thanks for sharing the video for others.  I have since swapped over to oem led headlights so not concerned about drl's anymore.  However one day when they stop working I'll probably just go back to the original halogen lights.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,166 Guests (See full list)
