8 hours ago, adan.barrera said:
installed 2" drop shackes but now im debating if i should do a 2/4 drop instead. not trying to cut it, all i want is something simple and clean.
Looks good. Maybe an inch lower on the front if you want to keep the back where it is. Otherwise, 2/4 would probably look pretty sweet too.
1 hour ago, mafd2 said:
I like the look of a 2" rear drop.  I added drop shackles on my RST.
That looks great. What’s shackles did you use?
3 hours ago, Low Elevation said:
Did you have to do any headlight adjustments after the shackles were installed?
Yes a little. Go on an even slab against a brick wall and use mortar joints as a guide. I use my local post office. You'll have to spin the shim around 180° between the bottom leaf and axle to get the correct pinion angle and prevent vibration.
    JD1964
    JD1964
  • Who's Online   4 Members, 1 Anonymous, 603 Guests (See full list)
