We have a 2015 3/4 ton Diesel Silverado, 4WD.
Can we flat tow this truck?
  • 1 month later...
Owners manual is your best friend:
Four-Wheel-Drive Vehicles
Only dinghy tow four-wheel-drive vehicles with a two-speed transfer case that have an N (Neutral) and a Four-Wheel Drive Low (4 (n) setting.
Warning: Shifting a four-wheel-drive vehicle's transfer case into N (Neutral) can cause the vehicle to roll even if the transmission is in P (Park). You or others could be injured. Set the parking brake before shifting the transfer case to N (Neutral).
To dinghy tow:
Caution: Failure to disconnect the negative battery cable or to have it contact the terminals can cause damage to the vehicle.
Caution: If the steering column is locked, vehicle damage may occur.
  1. Position the vehicle being towed behind the tow vehicle, facing forward and on a level surface.
  2. Securely attach the vehicle being towed to the tow vehicle.
  3. Apply the parking brake and start the engine.
    For vehicles with an Electric Parking Brake (EPB), the parking brake cannot be applied and the tires must be chocked.
  4. Shift the transfer case to N (Neutral). See “Shifting into N (Neutral)” under Four Wheel Drive. Check that the vehicle is in N (Neutral) by shifting the transmission to R (Reverse) and then to D (Drive). There should be no movement of the vehicle while shifting.
  5. Shift the transmission into D (Drive). Turn the engine off. Then shift the transmission into P (Park).
  6. Wait for at least 10 seconds, then restart the engine.
  7. Shift the transmission to D (Drive), then turn the engine off again.
  8. Disconnect the negative battery cable at the battery and secure the nut and bolt. Cover the negative battery post with a non-conductive material to prevent any contact with the negative battery terminal.
  9. Shift the transmission to P (Park).
  10. Move the steering wheel to make sure the steering column is unlocked.
  11. With a foot on the brake pedal, release the parking brake. Keep the ignition key in the towed vehicle in ACC/ACCESSORY to prevent the steering column from locking.
Edited by newdude
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 419 Guests (See full list)
