I’m looking for info on resonators and their effects on exhaust sound.  I need to quiet the drone at low rpm. It’s a little ridiculous. Lol
You may have seen my thread regarding my exhaust system on my truck.
LT headers, 3” ORY to xpipe, dual 3” 12559 magnaflow, 3 to 3.5” 12” long tips.  I’m either installing resonators or different mufflers. 85 mph is fine at 2000 but 70 at 15-1700 is annoying as F!
Ive read several pages on the exhaust thread but honestly I didn’t find what I need.  Looking for some insight.  .
Edited by 2015 High Miler
A vibrant ultra quiet resonator is what I would install.
The X-pipe is why it's so obnoxious, an H-pipe would likely do what a resonator would. If you can fit a resonator before the x-pipe it will help or install one on each side. The ultra quiets are kinda spendy but they work. I think vibrant makes bullet style resonators that are cheaper but they do less.
X piping is immediately after the crossover near the trans crossmember. It’s a prefab stainless kit.
I’m surprised the x is loader than an H. Maybe I misunderstood.  I heard a straight X and duals and it didn’t seem this loud, but I didnt ride in it. My truck isn’t that loud outside, even at 3/4-full throttle.
So, I would need 2 Vibrants for my truck. Any particular length or size?
thanks for the reply.
The size just has to match your exhaust piping. The length of the vibrant resonators isn't optional, they come as they are. Like 12in or 13ish inches long.
The bottle style are going to by half the cost of the ultra quiets just for reference. Amazon has the 1794 Bottle style in 3in pipe for like $54 each, the ultra quiets are around $100 each.
I'm sure magnaflow and others may make similar style resonators but I've personally used vibrant stuff and liked them.
The resonators helped a little.  But not $250 worth of help.  It still has a drone at the same RPM's. Its a little softer than before and most people compliment the sound from outside.   I probably should have bought a tuned system but at the time, I was not expecting this much of an issue with it.  Maybe I'm getting old like the truck LOL.
Swapping mufflers or installing a j-pipe style Helmholtz resonator is your next step.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
