Couple years back my 2006 silverado  would only blow hot air through vent even when A/C was on.
I replaced the actuator and it was fixed. not when heat is on only cold air coming in...
Will that be the same actuator again (one near floorboard) ?
Thanks
could be that, a bad  thermostat, clogged heater core. does the temp gauge read normal? if so check the heater hoses close to the firewall, they should be about the same temp with the engine warmed up and running at a high idle. if 1 is cooler than the other the core is clogged and needs to be back flushed. if thats ok do the actuator,
Engine temps are normal, after going down the road for few mile all sudden hot air returns until the next time you start off down the road. Would be the same actuator again if heater hoses check out?
Edited by man00
if the coolant levels full then that actuators on its way out it sounds like. yes same 1, controls temperature blend door. if it has 2 zone controls it may have 2 of them
make sure the doors moving free if you change the actuator, I know I have had a few pencils that have fallen thru my vents over the years that will cause problems someday
Thanks
Probably, especially if an aftermarket actuator was used.
Do you have dual zone climate control?  If so, does hot air come out of one side and cold out of the other?
Could also be low on freon if both vents are blowing warm air.
I have the two slider controls one for each side, when heater in on I get cold air out of both sides, when it decides to fail
Ok, heat out of both sides when it fails.  Does the air start to come from different locations, floor, dash, etc. too?  If so that would be the Mode Actuator.  If both actuators are doing this, I would suspect the controller and before throwing money at it, would hook up a Tech-2 and pull the internal BCM codes.  They will tell you what failed and why.
    tblt44
    tblt44
  • Who's Online   1 Member, 0 Anonymous, 514 Guests (See full list)
