On 11/15/2022 at 2:15 PM, movario said:
So, I replaced the valve body and still no difference.
BUT after replacing, I accidentially overfilled the transmission slightly. And the noise was almost always there and much louder. After I corrected the fluid level to the correct HOT level, the noise was back to normal.
So I suspect it has something to do with the fluid. Someone mentioned he changed the transmission oil to another manufacturer, and that solved the problem. I used Ravenol Oil (German Manufacturer) with Dexron VI specification. But maybe I should try AcDelco/GM Genuine?
movario did you replace only your valve body and not the TCU? I have the same sort of problem and wonder if it's the TCU/solenoid(s). I have a reman Dorman unit arriving soon but just want to try to understand everyone else's experiences before doing a bunch of work for nothing.
I only replaced the valve body. I kinda hoped that worn checkballs were the reason. But that wasn't the case. I also thought about a new TCU, but those are expensive and would require programming (as you can't get them preprogrammend). And given that Chevys aren't sold where I live, I wanted to avoid that.
Of course, always want to minimize part guessing!
Well I luckily had a friend who had a programmer, so I can actually even flash the TCU myself. Probably change that later this week and I'll let you know if the noise goes away. I'm also going to log before and after in HPTuners to see if there is any difference with the shift behaviors or shift speed.
  • 5 months later...
So, i was going to replace the torque converter but, it appears that is not the fix.  I have a 2014 Silverado and the sound coming from the transmission is exactly like heard in the video.  I did notice that replacing the fluid with Max- Life trans fluid helped a lot. Maybe a higher viscosity. Prior to that I used Castol Versatrans and the noise was much more apparent. This truck has been such a disapointment. Here's the short list:
Door Actuators (random locking unlocking problem) (replaced driver and passenger door actuators)
Water Pump (noise) (replaced)
Valve cover leaks (replaced gaskets)
Alternator (replaced)
A/c Compressor (replaced)
A/c Condenser (replaced)
Coolant Lines (heater) (replaced)
Oil Cooler Lines (replaced)
Rear End Noise (Rebuilt differential )
Hub bearings (replaced noisy)
Brake pad and rotor issues  (numerous front and rear)
Excessive carbon on valves (walnut shell blasting)
Trailer Controller  issue (Replaced switch)
Oil pan leaks (Resealed pan)
Rear Window inop (replaced rear window motor assembly)
Cooling fans randomly run at high speed (had to disconnect battery)
Thermostat stuck shut. (replaced)
Has anyone found this issue out yet? I have a 2018 GMC Sierra and I have the exact same noise at idle. It drives completely fine either on normal roads or going into highway speeds. No slips, not shutter or any sort but at idle does whine.
This is certainly not what we like to hear, Marcusvilla.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2018 GMC Sierra presenting a whirring noise at idle. To do so, please send an email to [email protected] with ATTN: Marcusvilla/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • Haha 1
  • 4 months later...
I have a 2015 suburbam with a 6L80 transmission and have been having issues with it for about 18 months, to sumarize at one point car just stoped and would not shift into any gear and i belived it was basicaly a transmission  replacement job. However i managed to get the car going again and drove it home, barely made it. Once at home dropped the pan and replaced the fluid and filter. No probelms for about 1000 miles and it started to whine while shifting into 3rd to 4th gear and severely overheating also. This time i took it to a garage and i belive they replaced the transmission Pump and the car was running ok but the transmission was working like the overdrive was on sometimes always 1 gear up. This went on for about 9 months and now the winning is back and the transmission is misbehaving badly. I am going to replace fluid and like all the other times it will go away for a while and come back winning. I would say that the winning is related to oil degradation as is no longer overheating. The question is what is degrading the transmission fluid? Any comments would be helpful.
  • 5 months later...
Hello I’m having a similar problem with my 2014 Chevrolet Silverado 2500 4x4, 6.0L
whining when idling in Drive, reverse, and manual mode. It’s only been doing this for about a week and yesterday it started shifting like a midget driving a dump truck… anyway, the fluid level is kinda high In my opinion and the fluid consistency is normal/average. I know a little bit about the world of mechanics so changing the torque converter seems irrelevant. I’ve tried to do some research to find out if this is a CVT type transmission, but I can’t find anything on it. I’m only saying that because I know CVT type transmission has an internal belt and the whining sound, sounds an awful lot like a belt, either slipping or freezing up on a pulley. But I never owned a vehicle with a CVT type transmission and I’ve definitely never heard the whining sound coming from any transmission ever. My wife wanted me to sell my Ford 7.3 L diesel and get this truck because the Ford was too loud. So please somebody help before I start rubbing it in that I should’ve kept the ford.. Only bring myself misery Because she will put me in the doghouse, but I won’t be able to help myself lol
    JWeather
    JWeather
  • Who's Online   5 Members, 0 Anonymous, 425 Guests (See full list)
