1 minute ago, BringTheRain403 said:
She was being a moody ****** again last night so I got clearer video.  Here are screen shots of the messages on the dash.  Video is uploading to YouTube.  I'll share the link once it's done...image.png.a03fc92c39289c4380876b858d19e8e4.png
I believe mine said key fob programming. I just went and disconnected the battery as soon as I saw it happen. My running boards get all whacky afterwards too. I guess some people have this happen and come back later and it's "normal". Each time it's happened to me I wasn't home so I didn't have the luxury. I put a 10 mm socket in the center console after it happened the second time. I never expected it to happen again, but I was definitely wrong. I hope they can figure it out tomorrow. Do all of your cameras work? My front is out all the time. Usually the others work. I got the weird blue screen once and it hasn't happened since.
Yes all my cameras work.  Never really had any issues with that.
Mine has been confined to the no start issue due to it being in remote learning mode and the dead battery because it keeps doing it over and over again and stays on for HOURS at a time.
Here's last night's video.  Skip to 3 minutes flat.  Nothing happens before that...
Edited by BringTheRain403
Mine just says the key fob programming part. At least that's all I've seen. Hoping for a fix tomorrow. I won't know until it's been a while. On average I've been stopped by jt every 10-14 days.
The second message comes up about 10 minutes later.  This is far more frequent for me.  I get in and can't start it at least 2-3 times a week and if I'm not busy and it sits for more than 36 hours there's a good chance my battery is gonna be dead.  My master window switch was replaced today.  Took about an hour and cost me $154.
Crossing my fingers the such fixes it for both of us!
Me too! Twice it happened on my lunch break, which I drive to daily, so I didn't have time to mess around. The second time, I was 40 miles from home and I was lucky enough to find something to unhook the battery with. Fingers crossed 🤞 for sure!
So I can report that I had no messages, screens coming on, or lights flashing on my dash while the truck was off in the last 24 hours.  Obviously going to keep watching it and I'm probably going to keep the camera on it for 3-4 weeks when I'm not in it just to be sure.  Also, plan on trying to let it sit without starting it for 4 days and see if the battery dies.
Fingers crossed the window switch fixed it!
Hope that was it!
13 hours ago, BringTheRain403 said:
Did they get yours swapped out and your cameras reprogrammed today?
It's in the shop right now. They might have to keep it an extra day. I am hopeful.
Fingers crossed!  I'm over 48 hours since they replaced the switch and there have been no messages.  Haven't started the truck since I got home from the dealership and the battery voltage is holding steady as well.  So far so good...
So, they pulled a TSB and went through all the steps which included six things. They also added an extra ground from the starter to the frame. If it doesn't fix the issue they will do the master switch. I ordered one online and will switch it myself. $50 shipped was fair.
As far as the camera situation goes, the programmer said we'd have to lower the camera in the grill 4.5" because of my lift kit. It wouldn't let him do anything. Something about GM cameras don't allow you to prvogram the angle like Dodge and Ford do.
I'm pretty sure I read that the master widow switch required programming by the dealer that's why I didn't mess with it myself
Hopefully my mechanic buddy has all the equipment needed if that's the case. If not my other friend works for a gm dealer. I'll have him hook me up. I'm going to look into that right now. I appreciate the heads up.
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 857 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
