Just tried again after an hour charge. Same problem. Also said service steering column lock. Left a message with my dealer service. Did a remote lock but headlights are not going off. I will give it a few minutes.
What a mess. I had to manually shut off the lights. Got all kinds of messages, service steering, battery save mode, battery low, steering column, lower window, etc.. SCREAMING!!
Does your truck actually HAVE a steering column lock? My '24 does not, and I got that message on mine at one point. They ended up having to re-flash the Gateway Communication Module because a bad OTA update sent me software that wasn't actually for my truck (and this is all-too-common).
Great point. In my frustration I didn't even think about it. Finally laughing.
The truck is with the dealership. I am expecting at least a month. I gave the techs permission to drive it anywhere they need to finally find a solution. We will see how it goes. Hopefully GMC will step up and help them figure this out. There are enough of us who have verbalized the problem, not to mention those who have not, that it should be a priority for GMC.
  • 2 months later...
Got mine back after months in the shop, again. So far, so good. Its usually about the time I start loving the truck again that it acts up. I had a heart attack a couple of weeks ago and I'm hoping things are fixed with the truck, finally. But if it does it again, the problem will probably take care of itself because that should give me the big one! lol
  • 1 month later...
Well, after months and months of downtime, the latest try (which was pulling a pin in the drivers door) seems to be the solution. I have tested it now for over a month and I have had no problems. The only glitch I have found is with my Kicker Speaker system in the tailgate (not very loud anymore) but that could be completely unrelated. Keeping my fingers crossed with the colder weather coming in I will use the remote start more often. But it seems fixed. Not having it several times for months on end kind of soured me on the vehicle but here's to hoping I can get some good use out of it now after a couple of years of this.
  • 6 months later...
What pin was pulled?  Sent PM
I don't know. Your tech can contact Fremont Motors GMC/Chevy in Riverton, Wyoming.
  • 4 weeks later...
So far so good for me after I fixed my leaky back glass.  Evidently water was leaking on to electrical connections back behind the rear seats.  The dealership was clueless.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
