I have taken delivery of my 2021 Sierra 1500 SLE. It's used and has this rotary knob/switch installed. It lights up in different colors when pressed and illuminates all or only a few LEDs when rotated. Any guess?
James
Brake controller.  More specifically, the Curt Mfg Spectrum series controller - Spectrum Trailer Brake Controller SKU #51170 for $250.58 by CURT Manufacturing (curtmfg.com)
More than likely was installed at the dealer because of the factory trailer brake controller shortage/constraint on these trucks that has been on and off the past year or so.  Its sold via GM dealers under part #19418031 and comes with a plug and play factory fit harness to power it.
Here is the link from GM's accessory sites - Spectrum™ Brake Controller Module by CURT™ Group- Associated Accessories | GMC Accessories
Edited by newdude
5 hours ago, James Mead said:
Thanks guys. Never seen one that small.
That's what she said?
Dammit.. missed the fact I was beat by 4 hours.  No option to delete :(
Edited by Rob Mugs
  • Haha 1
So, not to hi-jack this thread, but I'm curious if this can be installed after the vehicle was sold?  Is there any programming needed?  I have a 2022 1500 GMC Sierra Limited Elevation (Not the refresh model) with no trailer brake option.
S
I thought that immediately after i posted it
S
The factory one doesn't look like that.
That is the accessory one -- and it's available because the factory one can't be retro-fit.
Newdude posted a link to the page that shows it at GM Accessories.
It's made and warrantied by Curt
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,206 Guests (See full list)
