Hi there I have 2001 GMC Sierra SL wondering as it has manual mirrors could I put in Power folding and puddle light signal turn mirrors from an 2002 escalade and would I need the wiring harness how hard is it and has anyone done it any links ?? Thank-You
Edited by porra
Yes
Power folding is somewhat difficult going to need to find the wiring diagrams. The Esky switch is hard to come by but you could just do a momentary switch instead, a little more work for that.
The puddle lights you just wire into your courtesy light, I did that and it is super easy.
You can get the OEM switch on Amazon, it clicks into the pwr window cluster in the driver's door. I bought a replacement mirror on ebay for @95.00 but the "objects in mirror are closer than they appear is in Farsi~
The glass from my old mirror could be used so I bought it. You may have to get a pwr window/pwr mirror cluster though. My mirrors are heated and have the puddle light. Those aren't cheap. I think you are about to spend several hundred dollars if you don't buy your parts at the dealer I know the mirrors are in the high $200s, the switches are expensive too; so you'd be looking at around $400 to over $500 for the job. The wires may be included I donno, it might be less expensive to have ONE wire loom made up instead of many for the different options. Haynes repair manual shows "representative" schematics so there may be different wire looms... The mirrors come off easily enough and you can see the wire loom under the triangular cover just fwd of the door glass. I had a '99 GMc Tahoe type, I don't remember if it has the separate cover there like my '06 Avalanche does.
    250.3k
    nuchols
    nuchols
  • Who's Online   1 Member, 0 Anonymous, 558 Guests (See full list)
