Been a while since I posted here but I’ve done a few mods in the last couple months. I got my rear windows tinted limo, the fronts 10% and added a brow to the windshield. Truck is very dark inside but def makes a difference. I got new AT4 badges for the doors and tailgate with the AT  in gloss and the 4 in flat black, also got blacked out fender badges from the same vendor. 0FX2GV is his store- pricy but super high quality, way better than OEM.
this morning I had my tint shop install the front amber blackouts and do a smoke film over my taillights with the reverse cut out. I’m going to have them blackout the red on my third brake light as well.
Coming next week: 4” Rough Country suspension lift (went with lifted struts) and 35x12.5x22 Nitto Recon Grapplers. Wheels are 22x10 (-)25 offset Rough Country S95 with GMC cap overlays.
Edited by FWaT4
Looks sharp for sure! No fun keeping it looking that way!
