I had multiple leaking spots on a 2020 with sliding rear window. Dealer replaced entire window and water poured in much worse than before. At next repair, sealer was put on outside along top of glass -- all good so far.
The more i read about the leaking rear windows the more I think its just the sliding rear window leaking.  I have a truck without the sliding rear window and it was pouring rain today and i kept checking my truck for leaks and could not find any water leakage anywhere. Only the wet spots from rain getting inside when the door was open.
Yes the leaking has only applied to the sliding rear window. The plastic frame they used for them will crack and let water leak into the cab. I had my window replaced over a year ago with the updated window and so far so good.
Thank you for the clarification!  Do the normal door windows or anything leak?  Just curious if i should look anywhere else to prevent future rust/mildew/mold issues.
I've not seen any posts on the door windows leaking
Thanks.  :) I am good to go then.  I have other questions. Am unsure if i should make another thread or just ask here?
I'd make another post and say. I have questions on my truck. Then post all of the questions in that post.
Yes, all of my doors leak and my stationary back window leaks as well. Notice the back window leak when I wash truck, dry it off, then will notice water stain running down on inside of glass.
    JustusTX
    JustusTX
  • Who's Online   6 Members, 0 Anonymous, 670 Guests (See full list)
