Second EBC.
Seems like there are a few people out there, not GM specific, that state their Powerstop tend to fade when toying. They swapped out to EBC and had greater, percieved, performance.
4 hours ago, pokismoki said:
i would look at helper springs before i get bags, then if it still sags add a 2" block to the rear, then adjust tounge weight with adjustable ball hitch
Since I already have the air bags, I will continue to use those. But the option of adding a 2" block to the rear, although it would also work, it kind of defeats the purpose of leveling in the first place. I am not overloading the truck, it's fully within its capacities, the air bags just help with the load put on by the trailer. If I was running a much higher psi, say 60-70psi or even higher, tried to load up the bed with a lot of weight, and then hitched up the toyhauler, that would then make sense as it would be removing a lot of the weight from the leaf springs and concentrating the load all in one smaller section of the frame.
Take a read on this blog post:
https://www.autopartsco.com.au/blog/blog/lets-settle-a-few-myths-about-airbags/
Edited by mikeyk101
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   2 Members, 0 Anonymous, 571 Guests (See full list)
