Back story- 2014 silverado 4.3l v6 60,000 miles. Devloped a misfire waiting in line to get oil changed took to part store and they told me that I had a misfire on cylinder 2. Changed plugs and wires on all 6 cylinders and still had misfire. Took back to parts store and because the check engine light was on and they told me fuel injectors so changed all if the injectors and intake gaskets. still have misfire, had compression check and it was good also done fuel pressure check and getting good fuel pressure. I'm not really sure what to do next the only option left on the ignition system is to change the coils, but don't wanna waste $ if I don't have to.
Replaced all 6 coil packs and still missing, not sure what to do next!
Really wasn't sure what to do next so I just bought all 6 coil packs and changed them. drove it around and the misfire would happen intermittent and service engine light would come on and a few times the traction control light came on as well. Beginning to wonder if it's an issue with the active fuel management?
Edited by DINGDANG
 Engine has a slight miss at idle, stumbling abit and the rpm will jump as well
Post your fuel pressure readings. Also since you're doing everything else it seems, clean throttle body and MAF
Edited by txab
Cleaned throttle body and maf sensor. now the coolant fans are running constant, not sure if they are related. No engine light but still a small hiccup when idling. Drove a few minutes drives good but the fans are running. Engine is running Normal temperatue also.
Will have to to fuel pressure again, don't have the fuel pressure gage anymore. Buddy done it for me.
You don't remember the FP readings? Need to check them against the recommended spec.
So engine is running now with no miss? Or it just hasn't had time to show up? Did you disconnect battery while doing cleaning and use the proper cleaning agent?
Wrong plugs, or go overboard with antiseize?
If the CEL was on, the DME has stored trouble codes.  What are they?
Will check it out, went out to start it today and the battery is dead
Ran crc intake and valve cleaner, still missing, cel came on and stayed on. Took truck auto parts store and reader said misfire on cylinder 5. Took out spark plug out and it was broken, changed it and the misfire went away and the truck is running good now. Looking into buying afm disabler to turn it off.
    btm
    btm
  • Who's Online   4 Members, 0 Anonymous, 1,408 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
