Since I've purchased this truck new a little over a year ago, I've had issues with a loud pop coming from the left front area.  This pop only originates when there is a load applied (heavy braking) or unload (crossing railroad tracks, pot holes).  It's loud enough to have startled my kids and wife while riding along.  Dealer hasn't been able to find anything.  Just had an alignment done and caster on the left front was right at 3 (bottom spec).  As soon as I left the alignment shop and crossed railroad tracks, it sounded like a rod coming through the cab.
Any thoughts/ideas?
I'm leaning towards the caster being part of the issue, as I'm fairly confident in it being something suspension related.
Appreciate any help/guidance you all may have...
Any thoughts/ideas?
assuming 4wd? any additional lift besides the stock AT4 lift? maybe a CV axle issue? CV axle nut not tight?
Yes, 4WD and stock suspension lift.  Thought about the CV, but I'm only getting the pop under quick load/unload.  Thought i would experience it more regularly with a CV issue?
First thing I would do is get under there and put a socket on all the hardware and make sure everything is tight and nothing came slightly loose.
Edited by jaxcam02
Because its happening under a load, double check your bolts as mentioned above.  Start with UCA, LCA, shocks, and CV nut.  Its not often, but things came come loose.
Thank you
Thanks, will double check everything
Any thoughts/ideas?
This is certainly not what we like to hear, Cappy80.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 RST. To do so, please send an email to [email protected] with ATTN: Cappy80/Gm Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 2 years later...
Took my truck in with left front occasional popping noise. They loosened bolts and found one to be binding retorqued the bolts to factory specs and this seems to have cured the noise.
    Slow
    Slow
  • Who's Online   6 Members, 0 Anonymous, 955 Guests (See full list)
