I am looking at getting this setup for my AT4.  Will I still be able to run my OEM 20’s with 275/65R20’s?  Or is anyone running this setup, and how do you like it?  Will be getting 5100's for the rear also.
Thanks!
This is the same setup that I will be running in the near future, except I will be doing the 2" SST from readylift. The OEM 20's will still work with this setup. Post before and after pictures
and how you like this setup.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
