On 8/12/2024 at 9:44 PM, locospoker said:
I'm having the same problem with my 2016 Silverado. Can't find the problem.  I'm driving very slow 30 miles per hour.
I just started having this issue as well. 2016 Silverado 1500 LT 5.3L
This won't be your standard answer, but may point you in the right direction to the cause.
Driving under normal RPM, would run at 210. Stepping on the gas or going up a grade, it would creep to 250-260 needle pegged. I would let off the gas to drop the RPM and it would cool back down to 210.
Took it in and they did a block test, and it failed. Exhaust gas in the cooling system.
Either a head gasket leak or a crack in the block.
Vehicle overheats:
**FAIL BLOCK TEST** --REFFER TO ENGINE SHOP OR
DEALER
*FANS ARE TURNING ON, FOUND NO EXTERNAL LEAKS*
Got a couple quotes to replace the head gaskets and machine the head if needed. $4-5k
Got a quote to R&R the engine and replace it with a remanufactured  Jasper AFM Delete (no more dropping to 4 cyl.) engine (not a rebuild) with the Installation kit. $11k
Installation kit includes new water pump, fuel pump, thermostat, all filters, plugs, belts, and hoses.
I would rather replace the whole thing than nickle and dime the rest of the old parts after doing a head gasket\machine head.
Transmission was replaced 2 years ago (under warranty), so with a new-ish transmission and a new engine, i'm getting basically a new truck (I like my truck) for 1/6th the cost of a new one.
Dropping it off Monday and should be done by Friday.
Edited by Ron Sissons
  • Replies 45
Top Posters In This Topic
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
