So update on the truck. The engine blew on me i took it into a mechanic and his words “its toast”… i have no clue what happend it was running like it has been running hot and cooling back alittle and i got a mile from my house and it just crapped out. So we’ll never know what happend why it was running like that she took her secrets with her i just have to try and find a motor now
  • 3 weeks later...
  • Replies 45
Top Posters In This Topic
  • 3 weeks later...
Did anyone figure out this answer I have had the same exact problem and I can’t figure out why it’s overheating   No smoke no leak 2017 Chevy Silverado
changed water pump
thermostat
temp sensor
New fill tank
checked all fuses
changed water pump
thermostat
temp sensor
New fill tank
checked all fuses
The only thing i could see from when my motor crapped out on me is the air duct box that is infront of the engine has 2 hoses that connect to the valve covers and the hose on the passenger side had the connection for the hose melted and that hose wasn’t connected. Maybe thats why everything was out of wack and i just never saw it. Im not sure if that was the root cause or if that happened when my motor blew but its worth a look just to see if thats the issue
changed water pump
thermostat
temp sensor
New fill tank
checked all fuses
This is certainly not what we like to hear, Jack trotter.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2017 Chevrolet Silverado. To do so, please send an email to [email protected] with ATTN: Jack trotter/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 1 month later...
Hello I have a Chevy Silverado 2017 4.3 v6 I have been dealing with the same problem I have changed everything that has to do with the cooling system. I change the radiator thermostat thermostat sensor, water pump, coolant.and it’s still doing it did you ever figure out what was wrong with it ? I believe it’s the fans my fans are running very low maybe it can be the fan relays but I can’t figure out where they are located I know where the fuses are just not the relay
changed water pump
thermostat
temp sensor
New fill tank
checked all fuses
Did you ever figure out the problem?
I believe the fan relays are the 2 square relays on the left corner of the box. Check tjose it might be your fans not working right.
I figure it out i guess you can’t use aftermarket market parts it was my thermostat that I had brought autozone they look the same but it’s not I went to the Chevrolet dealer and got the oem and my truck is running perfectly fine now
  • 8 months later...
  • 4 months later...
www.gm.com
I'm having exactly the same problem with my 2017 Silverado 5.3. 102,000 miles on it also. Amongst multiple other problems I've had. Broken seat belt on driver side. Chevy claims not their problem. I feel it's a safety issue. And now after hearing about it blown engine I'm afraid to drive it. But I have to it's my only vehicle.
On 7/9/2022 at 4:28 PM, stu_pidasso said:
They're mechanics, they will figure it out. I'd say it's time to throw in the towel.
Yeah, but at what cost? $1,000 for them to replace everything and it still does it? My 17 5.3 Silverado is doing the exact same thing.
Edited by starmark
  • 8 months later...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
