Last week, I tripped my breakaway switch and locked up the trailer brakes when I made a tight turn & the cable hung up. I reset the switch & the brakes released but now I have no trailer brakes & I get the service trailer brake system error. Anyone have an idea?
Warning, I read about a guy that had a DOT/DMV check pull the switch to test the system. It blew his electronic controller. Be sure to un-hook the trailer plug from the truck before letting them test the system.
Edited by JimPetzold
  • JimPetzold changed the title to No trailer brakes after tripping & resetting breakaway switch
ok, I studied the system. when the trailer brakes are actuated by the breakaway switch, the power comes from the on-board trailer batteries (group 27 rv type battery).  It apparently back fed the power surge into the controller above the spare tire & fried that. ended up changing that and both 30 amp fuses, for the brake feed & the 12 from the truck to the trailer battery.
I purchased a Foxwell NT510 GM scanner and was able to read all the codes & could see the exact sequence of events that fried the controller, actually pretty interesting. After the controller was changed it still gave me a CCM code for lost communication & the fuse was the culprit. When I was on the road trying to fix it with nothing, I had swapped fuses with the trailer battery fuse and apparently that was blown too.
Great code scanner, I want to find resource to read more about how the onboard systems work, Guess that is just the nerd in me coming out!
Will make sure I have the tools &  spare parts on hand before I head out on a road trip again.
  • JimPetzold changed the title to No trailer brakes after tripping & resetting breakaway switch-- Fixed and a warning!
    Bert 22
    Bert 22
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
