No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.
I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?
These show the problem and symptoms, and I explain things too. to clarify again, I did not change over any computers or wiring (with the exception of the map sensor). All of the computers and wiring are original to the 2010 vehicle
video 1 - background info/explanation and part of the problem
video 2, idle misfire
I think the reason that the MAP sensor is reading High is because the engine is misfiring so there is less vacuum...
Additionally there's a p0102 for the MAF low frequency, and a p0108 for the map high voltage.
Again, apologies for the somewhat long-winded explanation, it's a rather difficult problem to explain without going into the details.
You'd want the Pulsar to be safe. That was the first product that worked for 10 speed trucks that they came out with.
Range Technology 22451 Pulsar LT for 2019-2022 GM Gas Trucks
That said, in the features description of the RA003B, it does list it working with 10 speeds. However there are reports that the RA003B can cause some drivability issues on early 10 speeds. So the Pulsar is the safest move IMO.
Range Technology RA003B AFM/DFM Disabler
Features:
Range AFM/DFM Disabler keeps you in full power 100% of the time
Simply plug into your onboard OBD-II port and it instantly begins working to eliminate the AFM system
Disables Auto Start/Stop
Blue LEDs
The Range AFM/DFM Disabler does not reprogram factory ECU
Works in hundreds of applications, 2007-2022, including 10-speed models.
Leaves no trace, unplug it to return to factory settings
Virtually no battery draw
Fits all V6 and V8 General Motors (GM) active or dynamic fuel management vehicles, includes cars, trucks, and SUVs
This device does not support the 2022.5+ Refresh model trucks or 2021+ SUVs
To confirm your 2022 model truck is compatible with this unit, check your VIN. The 12th digit in an early model must be a '4' or lower
Made in USA
