A lot of the Covid trucks are missing things due to chip shortage,  I see many have  "CREDIT - NOT EQUIPPED WITH REAR PARK ASSIST; INCLUDES LATER RETROFIT"   What exactly does this mean? Is this the lines that pop up in the camera when in reserve? I'm confused because there are a lot of different cameras, etc.
It the rear packing sensor processing hardware that gives you an audible (and seat vibration) warning that you are close to something while backing up.
Edited by reeseb
They give you a $50 credit now and then when the parts become available GM will tell you to bring it to the dealer for them to install it. However many people are already asking when is GM going to get the parts to fix my truck. This is going to be a nightmare for GM for a few years I bet.
Yes, I understand all that part. And agree.. it may be a while before they actually fix it.  I was just curious on what it does. I guess it's only the audible beep and seat vibration if you have this.  Does it still show the lines moving on your screen when you backup?
Yes I'm sure the lines are there as that is a part of the camera system. The park assist is the sensors that give the seat and audible warning when backing up.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
