Hello all,
I have a 2004 GMC Sierra 1500 SLE with under 90k miles. The truck is in good condition with no rust and runs great, but it's not immune to these GM gremlins.
My airbag light came on and it threw the code B0100. I found a used sensor on eBay that was verified to work for cheap enough. I put it on the truck (driver side, sensor 1), and it did not clear the B0100 code. When I manually cleared the code with the scanner, it came back. Since I thought I could safely assume the passenger side sensor was good since it was not throwing any codes, I took the impact sensor from the passenger side and put it on the driver's side and vice versa. Now it throws both a B0101 and B0103. When I put the old driver's side sensor back in the passenger side, I still receive those codes.
I'm stumped. Since it was not throwing a code for the passenger sensor before, my assumption is that it's good, but now the driver's side is throwing the B0101 code. There is the possibility that both the old driver's side sensor and the used one I just bought are both bad, but I thought there'd be nothing showing on the driver's side at all with the passenger side sensor plugged in there.
Where should I go from here? I checked harnesses and nothing looks corroded at all. Do the sensors have to be bolted all the way in before testing?
I received no responses here, but wanted to update in case anybody else finds this thread. Moving sensors around did not help. The passenger side sensor seems to have gone bad at some point during switching it around to the other side.
I ended up buying 2 new impact sensors (Dorman brand due to cost) and installed them and it fixed my code. I have driven over 100 miles now with no reoccurrence of the code.
The 800 series had an issue occasionally that could be cleared up by cleaning the mating surfaces of the hub and sensor with a file or similar. After cleaning everything is making good contact again
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
