Could really use some help an experience, in determining which direction I should go.
2015 Sierra, 5.3L
Driving around the other day, felt the motor bog down for just a second...pull over and pop the hood to see smoke coming from the AC pulley/clutch and it's not spinning....only the belt on the pully. After a little cooling, tapped everything with a heavy wrench...everything spins again, but only blowing hot air.  Remove the clutch plate to find melted plastic and the cover seperated from another plate, blued from heat.  Pulley spins by hand, doesnt sound like metal pieces inside/grinding.  With the cover in place, can't get the compressor to turn over. Who has seen this before, and knows whether I need a new clutch or a whole new compressor and condenser?
You need a new compressor assembly. Sounds like your old one grenaded, blowing crud throughout. Thoroughly flush your system and you probably need to replace the condenser as they are very hard to flush effectively and get them totally clean
Thanks. I think so, too.  I can't think of anything else that would stop the clutch and keep it stopped long enough, for the clutch to got hot enough to separate the cover from the plate.  Bought the compressor and condenser today.
I'd replace the receiver/drier also. Most compressor warranties require it
The receiver/dryer is something that always gets changed when ever you open up the AC system.  Just good practice since it is what keeps the system clean and dry.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
