I have had a 2015 Chevy Silverado Z71 for a couple of months now. My problem is warmer air blows out the drivers side vents and the passenger side is way cooler. Which blend door actuator controls this. There are 4 on my truck and before I go spending $ I hope someone can help.
I just had one replaced in my 2014 by a local shop, I would probably take it somewhere and let them diagnose which one is bad. They just labeled mine as temp door actuator.
This was located up high in the dash, between the glovebox and radio. A few years ago, I would have tackled this myself but I am not as young as I use to be.
I had this happen after the dealer replaced both headlight bulbs. It was weird like everything had been wiped out radio, seat memory etc.  but the most weird thing was the passenger side was blowing hot air when the drivers side was ice cold. The dealer said it was one of 4 actuators  going bad. They wanted to take it back in to further  diagnose but I didn’t have time or $175 per hour to spend.
I went home determined to figure it out.
I unhooked the battery and waited about 10 minutes and BAM! everything back to normal.
Strange but maybe a precursor of things to come.
good luck.
Edited by Wyatt1963
good luck.
I tried this method as well but didn't help me, worth a shot though. I bought the truck used and I was just glad it wasn't a condenser.
Ha!
I just replaced my condenser.
Another $500 but way cheaper than trading for a new truck.
Best of luck to you with your rig.
Edited by Wyatt1963
    Brandon 29
    Brandon 29
  • Who's Online   4 Members, 0 Anonymous, 416 Guests (See full list)
