I have a problem with pass side front turn signal, drivers side head light and both front fog lights not working. I have checked all the fuses and didn't find the problem. The relays seemed a bit warm.
I started up the truck before checking the fuses with a probe style test light. Several fuses didn't have power on either side. I thought this was a little strange since every GM vehicle I've ever owned has had power at every fuse once the engine was started. I don't think this is part of the problem with the lights, just strange to me.
I will be checking the ground strap next.
What are your thoughts on this problem?
2020 GMC Sierra 1500 Denali with 23K. It's lived in the NW all it's life. We hardly ever salt the roads.
Warranty?
It's still under warranty. Got an appt. for next week. Just curious if others have had a similar problem with the lights.
I will check the condition of the ground strap between the block and the firewall that's located below the battery today. I have heard of others having several problems that were resolved by replacing a corroded ground strap.
This is certainly not what we like to hear, jawsmon.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 GMC Sierra 1500 Denali. To do so, please send an email to [email protected] with ATTN: jawsmon/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    • I'm not sure what to say on that mess but I will say that is an odd thing for that mechanic to speculate on as per assuming its been run out of oil a few times as the odds of that engine having instead piled up with a complete seizure would be very high if such events had actually taken place. However there is nothing saying that the oil has ever been changed although once again, what filter was on that engine as that would tell part of the story if its possible to figure out if its a factory installed filter or not. Too many items unknown and a lot of speculation, but regardless of that its one fubared mess that is mind boggling to see for a vehicle that new and its hard to imagine how it ever made it that far in life looking at the top of the engine.    His scanners, I've watched him before here and there and I'd have to say if I recall correctly that some of his scanning equipment is one or two steps up from a child's Exo Sketch 😋
    • I agree. That`s a LOT of sludge for 12,000 miles. I tossed that out here since this is an OCI thread. There`s tons of people here that do not post.   I used to work on a city fleet. That includes police cars and fire trucks. Lesson is, not to only use the odo for oci. A police car has a ton of hours on the engine for the miles it shows. And, not just idling, directing traffic. They beat on these things.   Course, since it is a Kia, they were gonna use the "100,000 mile warranty" for their OCI.😉
    • CLASS ACTION SUITS?  Does anyone know if there is already a class action suit for the paint - which was to have been fixed, changed in after the 2020 GM vehicles?  Does it look like this?    Just started 3 weeks ago - No help from GM as of yet - Dealer will not assist in speaking with GM on my behalf. Confirmed it is the paint they use along with the way the put it on that causes it to fail.  Clearly a Manufacturer's Defect.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
