Had an issue where my truck was making a horrible grinding noise from under the cab.  Pulled over and had codes P0700 and P281B.  I had filled up with diesel fuel about 50 miles of freeway driving earlier.  Had the truck towed to my dealer and they said there was gas contamination.  My first question is, can you drive a diesel truck 50 miles with contaminated fuel?  Saw no black smoke, no performance issue with freeway driving.  The grinding occurred 50 miles after fill-up while taking the exit off the freeway.
Dealer then told me that the grinding and the transmission issues were not connected.  I am positive I did not fuel with gas and confirmed that with the station as they had video of me utilizing the green nozzle and hose.  No other reports of issues with the station.
Secondly, is there any way a contaminated fuel situation would cause the transmission issues?  The dealer did find fluid burnt and "lots of metal shavings on the transmission pan".
The dealer went through the protocol of draining and cleaning the fuel issue per document # 5207114.  They said that did the trick and there are no other fuel related problems.
Spent over 3K for the fuel issue and the transmission was all covered under warranty.  Not quite sure if all this sounds legit.
Any feedback is appreciated.
Tough spot to be in, I feel for you.
Sure, the level of contamination obviously matters but it’s certainly possible.
I think that would be highly unlikely. Given the fact that they warrantied the transmission, the dealer didn’t think it was the cause either. If they thought your transmission had issues because you allegedly put gas in your diesel it wouldn’t be a warranty repair.
What proof were you given that the fuel was contaminated with gas?
My have times changed. I put gas in my 97 Ford diesel all those years ago. The pinging was unmistakable. Luckily back then they had two tanks. I drained the gas, diesel mixture and put it into our 500 gallon tank at the shop. End of story. I got bad diesel at a truck stop in my 91 dodge diesel all those years ago. I was out of town. Other than changing the fuel filter way more often for awhile no harm. Either these diesels are way more sensitive. That’s advancement for you. Or they took you for a ride.
On 10/21/2022 at 5:50 PM, Grover67 said:
How many miles did you have on it when this happened?
-grover67
40K
I took the fuel sample provided by the dealership to a 3rd party testing facility (QUINN Cat).
I have a 2021 Chevy 1500 Duramax LTZ and tow a lot, usually around 7k lbs.  The truck does great but the other day it was really windy and I had a MIL pop up.  I checked the codes on my CTS3 monitor and it showed a P0700 and a P281B.  I cleared the codes and all was good.  Almost a week later I pulled onto a 50mph zone and cruised for about a mile when I came to a stop light.  As soon as I let off the gas pedal it sounded like baseball cards in bicycle spokes.  I wasn't towing so I immediately pulled over to the shoulder.  The noise was coming from under the cab/dash area.  Sounded like rod knock but at a faster speed.  It drove normal, just embarrassingly noisy.  I dropped it off at Molle Chevrolet in Blue Springs, MO.  They've had it for 6 days and claim it's an engine wiring issue.  He's had two techs look at it.  I don't believe a word he is saying.  My vehicles, like a lot of people in this forum, don't go to the dealer unless it's a warranty issue.  Both codes are transmission codes so how can it be an engine wiring issue.  He told me on the phone it runs rough.  It doesn't run rough, just loud.  I'll give him another chance to redeem himself or prove me wrong.  Otherwise I'm taking it somewhere else.  I posted this because my symptoms match Baker 5 to a T.
Thanks for letting me rant
Jamie
Jamie
When they got into my transmission, they noted "burnt fluid and metal shavings / chips" were found.  Apparently not the first time GMC has seen this as they approved the replacement as soon as the Service Manager sent in the request.
Have your guys dig a little deeper.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 5,695 Guests (See full list)
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
    • If your connector also has a big lever to get the connector on and off, you don't want to force the lever either way, as it becomes a bigger problem if you bust the lever or the mechanism it works.
    • It's just useful to disconnect the battery to prevent odd shorting out when unplugging/plugging stuff together.  I also  touch the two cable ends together (after disonnecting) to drain the small amount of stored battery energy in various modules.   I believe the main system where you need to be more concerned with, so you need to do the above and then wait some time, iss when you are working on the air bag system, to prevent inadvertent firing of the air bags.   The in-cab switches are just that, plain switches, it's generally not a problem to swap them in/out.  For my '12, I'll get an error message on the dash if I power up the truck w them unplugged, but that's it (power up= turn the ignition on).   The ITBC located above the spare tire is a computer that manages the trailer brake system.  That is probably more important to have the battery disconnected.  It does have to be programmed to the truck, either before or after it's installed, for it to work.  For my '12, I had a very hard time reinstalling the main connector to it (IDK if yours is the same or not), it turned out the silicon seal was jamming up, preventing it from going on all the way.  I finally got it fully installed by lubing the seal with a bit of dielectric grease, then it slid on and latched in place easily.
    • JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !   Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do , I will see if I can find it and post it up
