Installed a set of Rockblokz mudflaps on my 2022 Silverado LTD. Pretty satisfied with the look and coverage. Check out my install video:
Edited by fondupot
Fixed video link
23 hours ago, Traction said:
Nice! I have had good luck with that style flap in the past. Not sure about the front "flap on flap" look, though.
Thanks! Yea so far I am pleased with them.
I am also not thrilled with the way the front flaps on flaps looks either. But there is a hole in the body under the factory mud flaps that will be exposed if you remove them. And I didn't want that either.
There is a mudflap delete kit you can buy to cover up that spot, and then the Rokblokz can go right over top. Should look a little better. But it's a pretty pricey kit for a couple of pieces of molded plastic.
Link to mudflap delete kit: https://switchsuspension.com/chevrolet-silverado-1500-2019-2022-front-rear-mud-flap-delete-kit/
You can see the hole in the body, that I mentioned, in this video:
Edited by fondupot
