I've been annoyed to find that quite a bit of mud and other debris ends up on the body of the truck with the factory flaps.  Thinking about installing the Gatorbacks, anyone have any luck with them?  How is the install process?
Not Gatorbacks but I just installed a set of Duraflaps, they are great and very easy to install. They are kinda pricy but so are gatorbacks I guess. Worth a look you can get them in different sizes and art on the weights.
Installed the step back gatorbacks on my truck. I quite like them and they keep the truck alot cleaner than the stock molded. Install is great using all factor holes and not having to drill into the sheet metal.
I wondered if the stepped flaps fit over the stock extended flap?  It looks like that's what you have done but just checking to be sure.
Yeah I was going to ask that too because on an installation video I saw you take them off and replace with short ones they provide.
the gator back flaps look very secure but the way they mount looks a bit sloppy on the wheel well if I’m honest.
These ones fit over the factory extended flare. Did not receive a different cap with mine. They're roughly 2 years old, maybe the changed the design. The top clip is a pressure clip that latches onto the plastic flare, it is quite secure. Rest is factory screws holes. Zero movement since i installed them on 2 different trucks.
See link fo the ones i have.
https://www.truckhardware.ca/products/1070
Edited by CHIp070
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 792 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
