Hello, just picked up a 2007 Silverado 1500 z71 that has a 5.3 with a 4L60. I plan to swap in a 6.2 with a 6L80. Before you ask why I didn't just buy one with that setup is because I got an extended cab with the extra short bed. Which was only offered from 07-09. 6.2 wasn't an option then. I found a good deal on a setup out of a 2012 Denali with everything needed to do the swap, the only issue is the Denali was AWD. I know I will need to use a 4wd transfer case, hopefully my stock one, but I'm unsure of anything else I will need to do to make this compatible. Any input is appreciated. Thanks.
Edited by Tyson311
Always liked that combination.  You're going to need the Denalis cluster, drivetrain wiring harness and probably the BCM and many modules will still require programming to make it all work.
The MP3023 transfer case was used behind the 6.2s and the 6L80s.
You going to make a build thread?  Interested to see how this works out.
A Tech-2 or MDI with a laptop will make diagnosis and programming possible as they can talk to ALL modules in the truck, Engine, Chassis, Body.
Me too, took me quite a while to finally get my hands on a decent one. Thankfully the whole setup out of the Denali is close to complete with wiring harness and ecm. I’m sure it will be missing some components but we’ll see. Thank you for that tcase #. I’ll most likely try n make a build thread, it will be a long process. I have a Dirtking long travel kit for the front and plan to do some motor work before it goes in with plans of a supercharger hopefully. Thanks for the reply!
Cool, don't forget to shorten the rear driveshaft!  Consider getting an AXN rear axle, which is the 9.5" 14-bolt semi-floater that was used behind 6.2 equipped trucks (not AWD Denalis) and maybe the Vortec Maxx 6.0s.  It will bolt right up and come with disc brakes.  LKQ often has them quite inexpensive since everyone is looking for the 8.6.
Yup also the 6.0 Vortecmax. Almost got a truck with one, that didn’t work out though. I was definitely wanting one since i doubt the stock 10 bolt will be real pleased with all the new power and much larger tires. And yes definitely shorter driveshaft, going to be a 2 piece.
    250.3k
    user087
    user087
  • Who's Online   3 Members, 1 Anonymous, 818 Guests (See full list)
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
