yup buddy was going to buy my wheels and tires for his 22 rst and give me his old ones and they are different so i got new cheap ebay ones and hes going to ship me my old ones back later
23 hours ago, newdude said:
If for some reason they won't, you'd need a relearn tool.  I haven't had to touch a relearn tool on mine yet, even when swapping winters to summers.
Note from the operation of the system:
"If a new sensor has been installed or tire rotated, the vehicle must be stationary for about 20 minutes before the system can start the process of calculating correct sensor locations. For this to happen, the vehicle will need to be driven at speed greater than 20 km/h (12 mph) for about 10 min.
I started another thread with more details, but this did not work at all. At the suggestion of another user, I tried putting it in relearn mode. I had tried that previously three times and that did not work either. I even tried using strong magnets on the sensors without success, What finally worked was starting the truck, putting it in relearn mode, then immediately driving it. Even though it exited relearn mode as soon as I put it in gear, that procedure ended up doing the trick, as 9 miles later it recorded the correct positions. It's obviously a buggy, unreliable feature. Last thing you want is to be on a road trip and see your tpms system tell you need air in your left front tire, when you right rear tire is really the one with the problem! I bought a relearn tool for future use to ensure the system knows the correct tpms locations.
Bumping an old thread for a related question. Does anybody know if this issue applies to trailer  tpms sensors? I had a 2019 that came with a set of sensors that sat in my glove box for 4 years. I now have a 2023 and a trailer that I want to put the sensors in. Did the trailer sensors also change part numbers, and would I be able to program these ones on the new truck?
    Chris80s
    Chris80s
  • Who's Online   6 Members, 1 Anonymous, 849 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
