Hi to all. I read a few older threads about boxes that were built to replace the factory 6". But, it's seems no one is doing it anymore. The JL audio stealthbox is way too expensive & I'm not a JL fan. Does anybody know the box dimensions? I would like to make 1 for myself. Thanks for any help.
If you're planning on putting it in the center console or anywhere for that matter the sub you choose to use has required air space specs just use that to figure out your box design
Thanks for your reply. However my main concern is about the allowed space in the console. The max length width & height. I wanna pick the sub based on that. Just don't wanna go through the headache of taking it apart to measure, reassemble, then apart again to install
I have a sub box that was made to go in the console with a kicker 8” square sub. The sub has dual 2 ohm voice coils currently in parallel for a 1ohm load. I had plans for this to replace the Bose factory sub in my 2018 GMC but ended coming across a JL stealth box for a half decent price so the original plans have changed. I just haven’t had the time to post it up for sale.
It was made specifically for the kicker square sub which is what I put into it.
I’ll consider $200 plus shipping which is a loss on my side but I need to clear it out for room in my garage.
As a note, there is not as much space under the console as you would think since the transmission tunnel extends up into the console. Thus you are limited to the size of the sub and enclosure.
