I have a GMC Sierra 1500 2013 extended cab. I've installed the seven and a half inch lift. Installed 35s. Slight problems with tire clearance. Want to install a two and a quarter inch body lift to provide more clearance. Other than the spacers or anything else be required? Steering wheel extension?
Go with a 3" body lift I have installed many body lifts in my time things to look out for are wires when jacking the cab and bed up. A good kit will give you a extension piece for the transmission shift rod and a extension piece for the steering shaft to the steering box and a gas filler hose extension when lifting the bed maybe needed. Also you will have to split the fan shroud bottom half for when the radiator raises with the cab. Watch your upper and lower radiator hoses also. DONT lift the cab up with a floor jacks use bottle jacks floor jacks WILL shift the cab when jacking and make it very hard to line the holes up for the cab bolt holes. Hard lines for the brake master cylinder should flex enough. If you have a transfer case shifter on the floor you will have to modify that linkage also. Since you have done a lift on your truck it should be pretty easy for ya.
Thanks I'm going for RC 3-in lift. I've added a photo. I believe it has everything maybe missing the fuel hose.
After all that you'll want 37s!  What motor and gear does it have?
Here's my daughter's 2012 with a Zone 6.5 lift running 35s.  It has a 6.2 with 3.73s for now.
No I'm going to keep the 35s. But I'm bumps and tight corners especially at the same time, My front and rear tires will rub. Already ruined my fender flares. Plus I want to put two inch spacers on. So I'll definitely need the space.
    daveishi
    daveishi
  • Who's Online   2 Members, 0 Anonymous, 1,189 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
