Factory Shift Points
Hey fellas ... I'm filling out the order form for my very own Wester's tuned PCM and wasn't sure what to put as the shift points for WOT. So, if any of you know the factory shift points or would like to tell me what you set yours to (and if you like it there), I'd greatly appreciate it!
I need to know factory shift points for the 1-2, 2-3, and 3-4 shifts (all WOT). TIA! :thumbs:
edit: Oh, I've got an '02 w/ 5.3L and the mighty 4L60E. Hehe, got a little trigger happy and left out the important info! :cool:
Sweeeeet! Thanks Butch ... the order is placed and now the wait begins! :thumbs:
Full 93 tune, 5600 rpm WOT shift points, and lowered TM! w000t!!! :cool:
wooooohooooo!!!!!
No problem, Jarod--your PCM is shipping today.
Lyndon
www.ecmprogrammer.com
MAHA Chassis Dyno
1-888-WESTER-1
Dang he's fast!!! :cheers:
Why are the shift points so low at 5200rpm factory? I noticed that the few times I've gone full throttle in my new '04 5.3L? :cheers:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
