Largest tires that will fit on stock 18" for AT4X with 1.5" leveling kit and Rough Country Forged UCA
Hey guys Im new to the forum and wanted to get some good advice on the best wheel tire combination to get the most tire under my AT4x. I did the 1.5" leveling kit and swapped out for the RC Forged Aluminum Upper Control Arms. I am really hoping not to cut the truck but would like to fill out the wheel wells. I am open to any combination.
Using the factory wheels and swapping for larger tires
Upgrading both wheels and tires to achieve the best stance
I plan to use the truck as my daily so ride quality is important but at the end of the day its gotta look good!
Any help is greatly appreciated. There are so many choices and it seems like even the guys who are supposed to know don't always get it right.
This is a pic before I did the leveling kit and control arms. Its in the alignment shop right now and I will post more photos to hopefully help someone else out too.
  • Haha 1
I have a 23 elevation with a 3.5 inch lift, that I assume would be equivalent to the at4 with factory 2 inch and added 1.5. I can fit 285/65r20 with no room to spare. I rub slightly on mud flap at full lock, I’m sure I could fix with the bracket mod but haven’t been bothered enough to do it yet.
Yours is perfect not too much but fills out the wheel wells. Very nice looking truck.
Thanks
  • 1 month later...
So after taking delivery with 4000 miles I drove it 1400 miles before the 6.2 Engine blew up and it's been a month waiting on a new engine.... Not the most inspiring start to a $80k truck
Someone completely mistreated that truck for the first 4k....
Have you found out the cause?
    • I agree with Tim.  As tech heavy as engines are these days, no way I’d be an early buyer of the new 6.6.  Of course, I bought my ‘26 Denali w/the 6.2 after dumping my Tundra with it’s defective 3.5 liter imploding engine disaster, so I’m a little gun-shy.  That said, my 6.2 has been rock solid.  I don’t drive it like I do my BMW Z4 M40i, but I don’t baby it either.  I got a V8 for a reason.  But I’m averaging 18 around town and 22 highway.  I have seen 24 highway as well when I wasn’t loaded up heavy.  Considering my Tundra with the twin turbo V6 only got 14.5 in town and 17 on the road, I’ll take the 6.2 all day, every day.  If I were you, I’d grab a ‘26 while you can.  Inventories are probably gonna start dropping and I’ll bet the deals will start looking sweeter as well.
    • I am curious if anyone has figured out a way to add an hard button AUX or 360 Camera switch to the center row of switches. I have a 2021 AT4, and want to split the hill decent button and add a 360 camera button so that you don't have to go into the center display and locate the camera functionality, etc...   My father's 2024 Yukon XL AT4 and it has a hard button, see below. I found this thread on the Yukons, but it seems like there may not be a part number for the 2021 sierras. https://www.gm-trucks.com/forums/topic/255339-adding-hard-button-for-camera-on-2021/ Anyone else figured this out. Seems like it would need to be a custom switch!   I am getting ready to install the auto stop/start eliminator, so would be nice to knock them out at once.     Upvote1Downvote0Go to comments
    • Looks like the entire state is burning. 😬
    • Through the years it hasn't been my typical method as I tried to drop oil on an engine that was hot from having been worked, however that was not always practical and had to fire up a unit and let it warm up reasonably well and drop the oil when I had the time to do it but am referring to not only vehicles but a variety of farm equipment and highway tractors etc. However on a vehicle where one is crawling under it and the exhaust is nearby to ones body and if wanting to pull the plug without danger of being hit with boiling hot oil or attempting to remove a HOT oil filter, its sure safer and easier to not have everything smoking hot and can remove the filter right away when under the vehicle and let it all drain. Of course its not the end of the world if a bit of oil stays in the engine that might have eventually found its way out, I like to get out as much as possible but any oil changes that take place in shops would rarely be sitting around for very long at all before the plug is thrown back in and filter slapped on and oil poured in and sent out the door quick like. There would be very little time spent ( assuming they even did it ) in starting the engine with oil to fill the filter, then waiting to verify the level on the stick. A good reason to check ones oil level shortly after a shop changed the oil on a vehicle just to make sure its correct and to look under for any oil around the drain plug or filter.
    • Cool to see another Vermonter!
