Was under the truck chasing down a rattle and noticed the heat shield that hangs down on the passanger side of the ransmission pan is broken off where it attacheds at the top and only hanging by 1 of the two attachment points.  Anyone know the part number for this or where to find one? Also looks like it's bolted from the top so not sure how to reattached a new one?  This is for a 2017 with 8 speed transmission.
Thanks - I was able to get a part number stamped on it.  It's part # 2427111 for anyone interested.  It's what hangs down between the transmission pan and the exhaust next to the cat. What's strange is no matter which site I go to and type in Heat Shield even when putting in my specific make and model nothing comes up, but if I search for that part number, it comes up as Automatic Transmission Heat Shield.  Glad I was able to get the part number off it otherwise I'd never find it.  Hoping this one hangs on until the new one arrives.
Automatic Transmission Heat Shield 24271111 | GMPartsDirect.comAutomatic Transmission Heat Shield 24271111 | GMPartsDirect.com
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
