I recently got a code from th e dealer in regards to the Air Bag System. It was low voltage.
I removed the seat and saw the module was covered in wet sand and the carpet padding was soaked. To may trips to the lake and the beach. I think the rubber floor mats just let any water run under the seat under accelaration.
Anyway, I found the same part # at a U Pull Yard.
I checked the connections and replaced the module, after disconneting the Neg batterty cables for 30 min.
The error is still on the display.
I see from All Data, that the "set up SDM via the special functions" via a GM tech-2 scanner needs to be completed.
Has anyone replaced the air bag control module before, if so, was the BCM update required.
Asking to see if the module is picked up is also bad.
The process basically links the SIR module with the BCM, perhaps with some programming/configuration mixed in (as different vehicles will have different sensors/air bag systems).
From what I can tell, the GMT900's have the computers more tightly linked together, so you can't mix & match them like you can w GMT800 modules.
It's possible the module is bad, but you probably won't know until it's linked to the bcm.  It's also possible there are wiring and/or connector problems (as you mentioned there was a bunch of water around it).
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
