So I got the LT model and upgraded to LED bulbs.  I HATE that the low beams are also the DRL's.  I have the switchbacks for the blinker bulb and would like these to be the DRL's.  Has anyone done this or know how to go about the change?
Thanks!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
