For my next two issues, I am replacing the Oil Pressure Sensor, and repairing a broken Coolant Temperature Sensor plug wire harness.
Here is a picture of the Oil pressure sensor hole. I have the new screen in it. Apparently, it will not fit in there with the sensor. I checked and double checked to see if the old one was still in there. There was none in there. So, I just put the new sensor in there and plugged it in and everything works fine now. Another issue fixed.
Edited by Grubbworm
04 does not use the acreen. Do not install it.
Only AFM equipped engines require it
Edited by txab
Apparently, I somehow broke the connector off the end of the wire going to the Coolant Temp Sensor. I ordered a replacement from Rock Auto and installed it. Now my temp gauge is working again. Another issue fixed.
2 minutes ago, txab said:
04 does not use the screen. Do not install it.
Apparently not, I figured that was what was going on with it.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
