Hey all!  I've never encountered this before in a vehicle, is it potentially the fuel pump, or something related to the AC potentially?  Did a search and couldn't see anyone else with issues like it.
Thanks!
There was a problem on another GM vehicles as well and it usually requires getting air out of the system.
I have the same issue with mine ever since the lifters were replaced.  I betting that air got into the coolant system and just needs to be bled off.
Nick
I had the same problem since day one on my truck, and I was also steadily loosing coolant over an extended period of time.  I took it in and they bled/pressurized/flushed (or something) the system and both of the issues were resolved.
You have an air lock. This is why I always use a vacuumed fill on newer anything as they have so many spots to hold air in
New to the Forum and also first time Silverado Owner. Bought a 2021 Custom with the 5.3L. I have notices this recently after owning the truck for about 45 days now. No issues or leaks besides the noise.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,654 Guests (See full list)
    • I have 2 choices.
