Funny
seadoons
These are true...
1. Ever wonder about those people who spend $2.00 apiece on those little bottles of Evian water? Try spelling Evian backwards: NAIVE
2. Isn't making a smoking section in a restaurant like making a peeing section in a swimming pool?
3. OK ... so if the Jacksonville Jaguars are known as the "Jags" and the Tampa Bay Buccaneers are known as the "Bucs", what does that make the Tennessee Titans?
4. If 4 out of 5 people SUFFER from diarrhea...does that mean that one enjoys it?
5. There are three religious truths: a) Jews do not recognize Jesus as the Messiah. b) Protestants do not recognize the Pope as the leader of the Christian faith. c) Baptists do not recognize each other in the liquor store or at Hooters.
6. If people from Poland are called Poles, why aren't people from Holland called Holes?
7. Do infants enjoy infancy as much as adults enjoy adultery?
8. If a pig loses its voice, is it disgruntled?
9. Why do croutons come in airtight packages? Aren't they just stale bread to begin with?
10. Why is a person who plays the piano called a pianist but a person who drives a racecar not called a racist?
11. Why isn't the number 11 pronounced onety one?
12. If lawyers are disbarred and clergymen defrocked, doesn't it follow that electricians can be delighted, musicians denoted, cowboys deranged, models deposed, tree surgeons debarked, and dry cleaners depressed?
13. If Fed Ex and UPS were to merge, would they call it Fed UP?
14. Do Lipton Tea employees take coffee breaks?
15. What hair color do they put on the driver's licenses of bald men?
16. I was thinking about how people seem to read the Bible a whole lot more as they get older; then it dawned on me . . .....they're cramming for their final exam.
17. I thought about how mothers feed their babies with tiny little spoons and forks, so I wondered what do Chinese mothers use, Toothpicks?
18. Why do they put pictures of criminals up in the Post Office? What are we supposed to do, write to them? Why don't they just put their pictures on the postage stamps so the mailmen can look for them while they deliver the mail?
19. If it's true that we are here to help others, then what
exactly are the others here for?
20. You never really learn to swear until you learn to
drive.
21. Whatever happened to Preparations A through G?
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
