So my '17 XL Denali (magneride, autolevel, 6ZS/7ZS springs) sits low in the front (at least I think it does, compared to others and the tires scrape on hard turns) and the front is excessively stiff. Almost feels like it's sitting on the bump stops. Rear end is fine, normal ride height and normal softness, very easy to jounce.
I unplugged the shock on the drivers side and tried jouncing the vehicle but it made no difference. Very stiff, especially compared to the rear which is nice. The shocks (and I think springs) are OEM, BWI.
So, can/do these springs sag this much over the course of 5 or 6 years? The shocks aren't leaking as far as I can tell.
Either way, I'll be replacing both with OEM, and will see what happens.
They do sag over time and it's more problematic with 22s.  You probably need the shocks re-calibrated or replaced.  They have a service life of about 7 years generally speaking.
Use GM OE components.  If memory serves, new Magneride struts need to be calibrated.
This is from my shop manual, the previous generation to yours.
I do have the 22s, so that tracks. I'll slap shocks and springs on it and see what happens. Probably give my dealer a call and see what they charge for a calibration, if needed.
Replaced the shocks and springs with OEM. Driver's side shock was completely locked up and was pretty much sitting on the bump stop. Was a bear getting the spring off. Passenger side still moved but was also leaking. When I took the bottom shock bolts off the suspension dropped two inches. Not good haha
Rides much better now and I gained about two inches in the front. It's not butter smooth, but I'll take it over what it was. Maybe a calibration will improve the rider further. I'll give the dealer a call and see what they think.
Came across this today as I have a 2106 Tahoe with the same setup (but 20" wheels). My front end is sagging a good bit. I recently replaced most of the front end, minus the coils and shocks. From what I read, it looks like those two are my next steps. Any luck with calibrating from the dealer?
If you have magride and its sagging and stiff, its the struts.
    1GIO44
    1GIO44
  • Who's Online   4 Members, 0 Anonymous, 950 Guests (See full list)
