5 hours ago, davidm767 said:
Not a problem whatsoever...Its been a great add on and I've not had an issue with any of my Banks products so far. I wonder if you had leak somewhere in your system? Not on my current truck, but I had a Turbo discharge pipe silicone coupler somehow get loose a few years back, it caused all sorts of mayhem with codes and reduced power.
Thanks for the feedback.  I will try again once I get the DPF replaced to put them back on.
Anyone heard from Banks how things are coming along?  I guess we're looking at fall/winter at this point before we will see a release?
Starting to think its not going to happen to be honest.  Initially it was going to be Feb. then April, then June, now its September and no updates.  Half the time when I search for compatible products on their site it doesnt come up and half the time it says in development.  Starting to wonder if I need to find other options.
Jay from Banks here. The Derringer tuner for the '24 Duramax is absolutely, 100% happening. In fact, we have units being sent out soon to a select group of test pilots for evaluation. I have literally thousands of '24 owners signed up to purchase it when it's released. This is one of our highest priorities.
We're starting our Beta Testing in the next few weeks, which starts the countdown clock to its official release. Unfortunately, I don't have an exact ETA at the moment.
any updates in the pipeline for idash on the 24 L5P?
On 9/3/2024 at 7:00 PM, TurboTime said:
There will be updates to the iDash coming with the Derringer. I can't say give any details yet.
Any further updates would be great.
Thanks.
@TurboTime It's been a little over a month since y'all asked for Beta testers on social media. Any information on how the program is going? Are we looking at weeks or months until the release for our 2024's. I appreciate any information you might be able to release.
Just following this for updates as they are made on here. Have 2025 GMC 2500 with Duramax and interested in this as it becomes available.
There were rumors of a Black Friday release news, but that has come and gone. Banks has some very tight lips in their marketing department, not even some hints or teasers.
Jay from Banks here. We were hoping to surprise everyone and launch a few new products before Black Friday. Obviously, that didn't happen. While I can't disclose any updates, I can assure you that parts for the '24/'25 DMAX is very high priority.
Edited by TurboTime
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,769 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
